Posted 5/9/2018 16:02 (#6751943 - in reply to #6751465) Subject: RE: change variety in apex
SESD
Copy the field with the error to a test field or another unimportant field. Go to the newly copied field and delete all areas that have the correct variety. Then use edit to change the variety name to the correct variety name of the remaining area. Then merge this field (corrected area) back into the original field.
