N Central IA | Here's what I have JD 9220 wired for greenstar less steering valve. Greenstar display with mobile processor and an OutBack S-2 or S-3. I have the harness used to connect my OutBack to the greenstar in the combine for yield mapping. If I buy the JD steering valve can I steer this tractor using the OutBack as the receiver like I do In the Combine for mapping? If this will work can I use my OutBack Baseline for more accuracy. Seems like it should work, anything else I would need to do this? | |
