Mid Michigan | Are you talking about the Kats magnetic heaters? I would probably do it. I bought one for use on my Ford 9n but it didn't give off very much heat on there. Was easier to fix the starting problem. Now it starts in 10 degrees with no problem. But I would think a 200 watt would be good for maybe a 25-50 gallon diesel tank to keep the fuel from gelling without overheating it. Sure couldn't hurt to try. about $20 bucks if I remember right at TSC.
Edited by davpal 1/5/2009 16:43
