roaming | mtbrights - 4/16/2018 06:45
Could someone refresh my memory on transferring one afs 700 set of boundaries to another unit. Can I just do it under file export. Thanks
Edit, I will be coming FROM version 28.6 TO Version 30.1 if I recall exactly.
No special process. Take the USB stick from the first display to the second display, insert and power up. The boundaries are now available.
Remember that boundaries are only stored on the USB stick. So if you need to get boundaries on 2 displays at the same time, you'll need to copy the ENTIRE CN1 folder from the first display USB stick to the USB stick for the second display. |
