NW Missouri | Thanks. A local dealer had the seal kits on hand, so I picked them up yesterday and it's already back together. One ram had gotten a little bent and the other one was a little pitted, and both needed seals so I thought if I could pick up used ones for cheap, I wouldn't put money into these. But the seal kits were only $100 or so, and I was able to straighten the bent ram, and I smoothed up the pits quite a bit so it should be good to go for a while again now. We've had this loader since the early 80s and this is the first time we've had to work on the cylinders, so that's not too bad. | |
