NE CO | Have you tried recalibrating the Autotrac system? Depending on the age of your sprayer and software payloads, you might have the option for Autotrac Calibration under the Vehicle Calibrations tab in the sprayer settings. Give that a shot if you do and then set you steering sensitivity back to 100 and all the advanced settings back to default and start from square one. If you don't see the AT Calibration option under that settings tab, it is still possible, you just have to access the right steering controller address in order to do so.
Sounds like you've covered all the other bases already and if calibrating the valve doesn't help, you might have a mechanical issue of some type. | |
