SW Minnesota | I just purchased a Massey-Ferguson 7622 tractor. It says that it is Autoguide Ready so I assume that if you are using AGCO-backed GPS equipment, you would be able to get a receiver and a display, then plug and play. (I assume this would be TopCon). I am planning on using an Ag Leader system with this tractor. Can I do the same thing with probably just some sort of adapter harness? Or is there some sort of controller kit that you need as well?
Thanks for any input. | |
