Posted 4/8/2018 17:54 (#6696800 - in reply to #6696726) Subject: RE: Ag Leader PPM with implement switch?
Your welcome. In your case with a PMM only the shaft rpm sensors will trigger the map coverage. You'll need to add a sensor per shaft section. If you add any other Ag Leader CAN A modules then you will need an implement switch.
