1680 unloader won't swing out
wilb
Posted 10/3/2006 22:44 (#48543 - in reply to #48499)
Subject: Re: 1680 unloader won't swing out
Had a similar problem with a 2004 2388. It was the switch that stops the auger when it is fully extended (located on the edge of the hopper where the swived is). We just put both wires on the same terminal and it worked. Just had to manually put the switch in neutral before the clylinder hit the end of the stroke.
