Central Minnesota | That's what it sounds like is the feedback sensor. Had the exact same scenario with a sprayer. If I remember correctly you take a piece of wire and jump the signal and the ground?? And tap the wire on the pulse wire to simulate a signal then have someone watch in the cab to see if your getting feedback. You should change your feedback cal number to a low number also. If you get nothing then it's a wiring issue not a sensor issue | |
