terralex - 3/27/2018 17:09
I am wanting to add an separate antenna on a tower to my base station. The JD manual lists off a 7db high gain antenna, but they want $1500 for it. I have found a couple of other antennas online, the first is a 450-470Mhz 3dbi antenna (my frequency is 463.75) $150. The second is a 430-470 Mhz 7dbi with what appears to be similar specs to the JD version but costs $513.
The 3dBi one would give me approximately the same output watts as the 2dBi whip antenna I am currently using.
Edit: Will one of these options work for me? My local JD and UHF radio people are not much help with this.
