Posted 3/24/2018 16:07 (#6662777 - in reply to #6662704) Subject: RE: 4710 sprayer throttle problem
Puckerville Dead center N.Y.
Curious what the answers you get will be. I have a 4700 with the same problem. Found if i leave the rpm s just above idle when i shut it down the problem never shows up. Last fall i did push in on the throttle a little after i forgot not to go all the way to idle and that seemed to work but if you changed the switch in the cab that's probably not your problem.
