Search Forums | Classifieds (4) | Skins | Language
Trimble rate and section control module problems
MTD
Posted 3/21/2018 20:24 (#6656850)
Subject: Trimble rate and section control module problems
Sw kansas
I use my Trimble 750 with the section control module to run my sprayer. So today I was rinsing the sprayer out and just using the test mode to spray it out. While I was spraying it out it would all of a sudden shut the boom off except for the two outside sections. If I would shut the gps off and unplug the module, start the gps and plug the module back in it would work for a bit again and then repeat. Also it will say on the screen that the module is disconnected and also sometimes say to check cables and fuses. I had another module I wasn’t using so I plugged it in and thought I had the problem fixed. It’ll run longer but it’s shutting off to but so far it shuts the whole boom off. I’m not sure what the problem is so i wonder if anybody has any ideas? Thanks
