Tomball,Texas | The problem may not be your electric shutoff,our 5288 would start fine cold but wouldn’t restart hot and the problem was the injector pump,you could pour cold water on the injector pump and then it would start,something would expand in the pump when it was hot and it wouldn’t make enough pressure to fire it up.
You might try to pour ice water on the pump when it’s hot and see if it starts.
I know it sounds crazy. | |
