SW MINNESOTA | I talked to my dealer today and he thought it would work. I think you need a micro trak flow meter. At least that’s what I was told when I used a RUM based system, I hope it works with the SRM setup. Dealer was going to check for sure on pinout on the swath output harness as to weather the 12 volt output is hot when meter is running or hot when off.
With the row flow system you could run a piston pump with a hydraulic motor but I’m not sure if a vdrive setup will allow that.
I have looked at Vapply, looks like a nice system but just too expensive for what I need. | |
