nebraska | I think your going to find out that you will have pulses in your seed meters from connecting to the same drive to run your pump,, each piston stroke will transmit through the drive shafts,, maybe you won't notice it though,,
. On the 1770 nt they have a separate drive off a main lift wheel, wheel to wheel drive,,. If your interested I have a complete fertilizer drive wheel assembly from a 1770nt you could modify maybe to use on yours,,
Edited by GT500KR53 3/12/2018 20:03
