Posted 3/12/2018 19:41 (#6637983 - in reply to #6636944) Subject: RE: Where to run power from battery to cab JD 7810?
Swaledale, IA
Not the same tractor but in our Magnum the installer found a good spot in the floor behind seat and drilled a hole made access much easier than snaking a wire out through the window. In my sprayer I did the same thing but right in front directly above the batteries.
