Posted 1/18/2018 21:29 (#6515743 - in reply to #6515613) Subject: RE: Pipe post? Cement or push in?
West central missouri
If you drill a hole with a slightly smaller diameter than your pipe, it will work fine. The problem will be to keep your drill from walking when you start the hole. I would use a good driver and put them 5 to 6 feet in the ground. You don't want them angled all different directions in a few years.
