SC MN | I like the wet shelf feeders, easy to install, easy to adjust, and save water, and no moving parts to wear out. I presently have Crystal Springs in most barns, but am going to be using some SDI's to update one barn. I looked at some of the different makers you listed online, and their shelf feeders seem to have a lot of the same features. Main concerns would be metal thickness and shipping cost. One thing I would watch is how wide each feed hole is. The new feeders I'm getting have 16" wide feed holes vs the more common 14". If you're taking your pigs to heavier weights (275+) get the wider feeder space. | |
