Posted 1/20/2018 20:28 (#6519805 - in reply to #6511650) Subject: RE: Anyone know anything about the battery in the AgLeader Insight?
NW KS
Are you sure the second part number you found is correct? The battery in your photo is 7.2 nimh. NIMH batteries have a nominal voltage of 1.2 volts per cell so that would make the one in the photo a 6 cell battery. An 8.4 volt battery would be a 7 cell battery. I have no idea if you could get away with using the higher voltage battery or not.
