| We run a CNH 2166 combine with an Integra display. I noticed that when harvesting after dark (after I turn on the lights), the moisture value on the Integra starts dropping. So my 17% corn would be reading 8-9% on the monitor after a while. It didn't drop immediately, just after running for a while. It also looked like the battery gauge was dropping below normal. So it seems to me like we have a power drain somewhere. Will a power drain cause the moisture value to gradually get lower, or is there something else that could be wrong? Also, does anyone have any thoughts on how to fix the problem and/or what else I should be checking? | |
