Posted 1/16/2018 17:33 (#6510149 - in reply to #6509923) Subject: RE: Fertilizer tank
WC Ohio
I would use poly everything because it is a poly tank. The poly fittings are easier to get to seal up than stainless. I would use a banjo 3” full port valve on the tank. You can get lockable handles for the poly valves if you are required to lock the tanks.
