Posted 1/16/2018 11:51 (#6509505 - in reply to #6509391) Subject: RE: 3020 hydraulic issues
West Central Iowa
+1 Would also try swapping hoses L to R to see if it works any better. Can it lift the disc back up after you have set it on the ground? If it does, it is likely not your max PSI causing issues even though there could be other internal flow issues if it ends up not being the cylinder.
