Posted 1/16/2018 06:28 (#6508751 - in reply to #6508670) Subject: RE: Any jd techs with experience on planetary on 9300T
Davenport Washington
Planetary is full it only leaks while sitting but leaks enough that it runs down the wheel. I am going to pull it apart would rather work on it now then when I’m in the heat of things only 1 tractor so I need it to run.
I looked at the parts break down and think it has a similar style seal plus shims for the bearing so I’m guessing that the bearing could be a little loose. I’ll tear in to it today and see what I find.
