| jd8560 - 1/13/2018 09:11
When you create n AB line on JD. You’ll need to create it as a non JD guidance line. Then when you bring it back in to the 700 they will match up
It won’t actually work that way, as all that is exported and imported are the A and B points. Deere lines are generated slightly different between these 2 points, so the display has to be capable of generating these different lines, as well as subsequent passes. |
