Wisconsin | Correct you have to re-create the AB Curve no way to delete section of the ab curve. Your on the right track with pausing. Often if most of the pass is straight I start then pause, drive and un-pause make the curve, pause then go to end and un-pause. Pause/Un-Pause snaps a straight line so only the freeform curves. Keep curve as minimal as possible as sharp curves are hard to plant, spray, and harvest and striptill is hard on equipment twisting tightly. Sometime we AB Curve the first pass then Straight track the rest of the headland rows.
