West Tennessee | Everything you've been told so far is correct there is no adjustment for this other than to put the pittman arm on a different spline. Then it will normally only go on in one position. From what you describe it doesn't sound like yours is far enough off for it to even be off a spline if that was possible. We've had ours off more times than I want to think about. If you've got the right drive head on the sickle, could there be something wrong inside the wobble box? | |
