Posted 12/30/2017 08:42 (#6463781 - in reply to #6462666) Subject: RE: If I update my Direct Command module will my Insight still work with it?
North Central Ohio
You can roll the firmware back if needed. I just put an insight back into a dry machine that had an integra. It registered some errors. I went in and manually rolled the firmware back on the dry module. Works fine now.
