SCIA | If you are already using Integra/Intellislope on the plow you are "using", some one has to have RTK. Why can't you use it? If the Ditch Witch is not contolled by the pitch of the boot, you would, when doing the set up, change the control type to non pitch. This tells the control system that the pitch number and related info are not to be used, only elevation. Should be relatively easy to do. Need something to mount the rover over the point of cut, (like the arm on the plow), a proportional valve and what ever cabling that you do not want to move from one unit to the other.
We have done several of this type of install, on diggers, commercial plows and scrapers. If you want, call me, six41 three 44 one723 | |
