Nw Iowa | Pretty common problem, our local tire dealer stocks them. I believe they are somewhere between 1600-1800 and that would be for the larger metric tire rims. Graham tire from Fairmont Mn ,sent out a truck with two guys and in just under 2 hrs had combine jacked up, inside old rim off and tire put on new rim, reinstalled on axle and jacks loaded and we were combining again. Unbelievable. Hats off to Brad and his crew. There is a inside and a outside rim. They have slightly different offsets, at least on a 680 with the larger, fatter tires
