Morris, IL | Dan, i think i just replied to your email last night about the check valves. Have a 7200 all monitored by agleader Integra. I have electric pump running in furrow on top of the squeeze pumps running 2x2. Overall i like this setup although i think if i was to start over i'd go hydraulic centrifugal or ground drive piston. Here is why electric is nice cheaper route i think long term higher operating cost then other two options. Limited on rate and pressure a little.
I don't think there is way to monitor squeeze pump flow with agleader.
I monitor seed flow, advanced monitoring. I monitor downforce to tell what is riding on the gauge wheels. I have precision seed tubes and run them with STMM with no power module, have no problem here. At some point i really need to get clutches on our planter. | |
