Posted 11/10/2017 10:34 (#6356689 - in reply to #6356662) Subject: RE: Flex head on frozen ground
Northeast Missouri
If your head will not stay down look to see if the actuator rod return spring is broken. It's on the left side by the wobble box. This will cause the symptoms you describe.
