roaming | iowafarmk - 11/8/2017 08:30
I've been doing some tillage work and using the Pro 700 for guidance, and approx. every hour or so a screen will pop up telling me i need a new operational instance. I create a new operational instance and the issue disappears...for another hour or so. I've never had this issue planting and have only had it once in the combine on a larger field. Was wondering if anyone else has had this issue, what the cause is, and possible solutions. Thanks.
You get the warning every hour? That's not normal. What is the specific error code? What version of Pro 700 software are you running? |
