thanks for follow up Jim
Glenn (Whitey) at Far Better Aberdeen, explained something like that, but said they put a flex peice on the end also, probably cut the stainless up higher........to keep rocks from bending stainless in toward seed slot
not sure how that would all fit and perform w/ drag chains.......drag chain solid strap might keep flex hose from putting 28% right on seed
wonder if dirt in drag chain would create a wide enough U in the chain to put dirt over fert band......think so | |
