| If you wish the exact number do a calculation as follows.
Suppose you need to mix more than 2 grains, suppose they are 3, and you know for the 3, wet weight and moisture.
a- Multiply for each one of the 3 wet weight by its moisture and after sum the 3 values.
b- Sum the wet weight of the 3 grains.
Third divide a by b, the number is the moisture value the mix is going to have.
Same procedure can be used if grains to mix are between 2 and infinite. | |
