roaming | dawdge - 10/21/2017 17:53
Trying to harvest a half pivot and used the 3 mark and continuous in circle. And the nudge keeps adjusting is self to the piont where im leaving a skip.
What do i have set wrong?
Nudge is adjusting itself? So if you don't touch the Nudge button yourself, the value changes? What DGPS correction are you using? Is it reliable, or are you losing signal periodically? |
