NW Iowa | I believe you have two options.
1. Buy an ATU steering wheel to put in your Steiger. Can get them for $1000 or less used. Should plug right into your green star harness. This would be the cheapest/easiest route, but you won't be utilizing the autotrac valve.
2. Deere offers an autotrac kit for CaseIH tractors (I think Raven actually makes it). Last I remember it's about $3,000 or so. You'll be able to use the Case autotrac valve this way and utlilize the Case ISO plug at back of tractor. Takes about half a day to install the harnessing and controller. You will need to switch some pins around in some of the harnesses and install a new resume switch as well. I have been running this in a 315 for a few years now and it's been working well.
If this is a short term deal of running the tractor with your green star equipment, I'd go the ATU route. If you're planning to keep the tractor a while and continue using green star equipment in it, I'd recommend spending the money on the kit.
Edited by jbcent 10/9/2017 07:38
