| The newer ITC receivers have two connectors on the receiver harness, one connector has the pin out for radar and RS232 while the other does not. The PF90350 harness that the dealer was trying to sell you has a "Y" end on it that is supposed to plug between the cab harness and the receiver. It is possible to plug the harness in wrong and not get signal out where you need it on the other end of the harness. Chad is correct in saying that you can install your own wire into the connector and achieve the same result by running it into the cab, tapping into the radar circuit "209". The Deere 30 series tractor has radar or GPS speed plugs in the console that can be switched but the 20 series did not. | |
