Posted 9/21/2017 11:02 (#6261395 - in reply to #6261236) Subject: RE: Dole 400 moisture tester
West Central, WI
Take the dole and a sample of grain into your local coop. Use the same sample they test. Turn the flat head screw located under the bottom tray next to the 9 volt battery to match their sample. Turn the screw little bit at a time.
