Alton, Ia | I've got a 900 series, so different Infoview, but can you go into it and watch the voltage sent to the drop valve, see if the valve is being instructed to open wide? If it raises fast, compare the voltages between the two as you cycle it.
If it's being told to open wide, and doesn't, then you have a hydraulic issue. If it's not, then you have a computer issue.
Hope this helps. | |
