Search Forums | Classifieds (19) | Skins | Language
JD 9500 reverser problem?
yellerfeller
Posted 9/20/2017 19:33 (#6260069)
Subject: JD 9500 reverser problem?
Wondering if the FH reverser has gone bad. Started black beans today and header/auger will stop when it starts to drive harder. Makes a grinding noise like gears slipping. Also, slips in reverse as well with same noise. If I clear it all out, it will turn but only until it gets a load again. Not sure if it is a slip clutch or the reverser.
Any help appreciated.
