Posted 9/18/2017 12:51 (#6255224 - in reply to #6255201) Subject: RE: Anyone control this type of tile plow with AgLeader?
Fargo, ND
You have to have a proportional valve of the type AgLeader uses. Parker PWM proportional.
That front cylinder you are controlling takes a lot of oil flow so that Parker valve might be a bit small. The bang-bang valve you have was probably pulsed by the laser system to give you better response. Intellislope will open it wide open or shut it off.
I tried that once with a bang-bang valve on a Wedge plow mounted on a TD25 crawler.
