| If you have a full set of weights on the front there is no need to add more, when you drop the cultivator it throws the wieght back on the front end. Have you tried adjusting your steering angle or line accusation setting? What signal are you running? A weave like your talking about is common with a WAAS signal. Make sure you have your diif lock on when you are on the line it makes a good bit of difference. | |
