Posted 9/4/2017 07:21 (#6227634 - in reply to #6227501) Subject: RE: AFS 600 monitor, New problem
North Dakota
fault is for the engine. 1685 means the ECU has reset itself because of a configuration error. Could be caused by low voltage at startup or a failed hardware test. There is most likely another fault for a sensor that is causing this error or batteries are low enough to cause a brownout of the ECU.
