Posted 9/2/2017 14:57 (#6224869 - in reply to #6224744) Subject: RE: Sending speed signal from pro 600 to a ravens 440
roaming
mcnaull82buckeye - 9/2/2017 12:13
Wondered if there was a cheap way to pull the speed from a pro 600 on a case 8120 combine to a ravens 440 that I am going to use to control cover crop seeding with on the combine. Combine as auto steer if it maters. Thanks
Not from the 600, but you can send simulated radar to the 440 from the receiver (if it's a 372).
