Thumb of Michigan | Going to spread every day until drydown. White mold is our biggest problem here in soybeans. Rarely get Temps in the 90s or above 85 which destroys viable spores.
You should expect significant yield loss and lots of black shrunken diseased beans. If the variety has some tolerance might not be so bad but white mold tolerance probably doesn't make your needed plant characteristics short list in Indiana. Not much you can do at this point.
Good luck | |
