Posted 11/24/2008 17:02 (#515599 - in reply to #515576) Subject: Re: Inexpensive ideas to map yields?
SE Wisconsin
That will be cheaper. You will have to find out what processor you need, I am guessing its the one that piggy backs on the GS1 display. That will probably cost you about $800 with the key card included. All told it will probably be around $1200 for parts. The only problem you will run into is you need someone with some experience with the hardware and software to install it.
