| Im currentlly plumbing my sugarcane planter to run on the tractor hydraulic vs a pto hydraulic pump. I have the big motor return line ran into the motor return. There is a electric dump valve that controls the other motor to push the table of cane forawrd when the computer box and pressure sensor says to. Any way i can run this return line into my case drain port on my tractor instead of the valve stack.
I tried to T the two return lines with a 1inch line back into motor return and didnt have enough return to keep up. | |
