Posted 11/20/2008 10:44 (#511645 - in reply to #510242) Subject: RE: GS2 rate controller problems
My mistake, I was trying to run my liquid raven setup with a NH3 harness. The only difference is that you have to move pin 18 to pin 4 on the 37 pin connector to make it a liquid harness, then you have the pressure transducer connection so you get pressure on the gs2 display. Thanks for the ideas.
