Southern Nevada desert | I ran one for a few days on my 7810 with a 750 and auto pilot pulling a challenger PTD15. I just set it up in the display as if it was behind the tractor then swing it to the side and start cutting and tweeked the position of the swather tounge to match the line the tractor was on. It worked fine on omni but "here" wass is not even close to working for cutting hay in circles because the center point keeps moving and nudge just moves you in or out in the circle it does not shift the center point, I dont have any square fields, wass may work there.
Edited by Two Hawk 6/29/2017 23:52
